Do you have to install it on each start? That kinda sounds like a pain in the arse.
Zac
So people who live, say in a condo and park maybe
100 feet from their third floor unit and can't run an extension cord are SOL... good idea though... in principle.
1995 540i Manual build 1/95
If you live in Scandinavia for example, many of the parking lots have a power connection for this.
When I lived in Canada, my cars and trucks each had a block heater, and sometimes two in the V8s, that were installed in freeze-plug holes. Never tried a pan heater, but probably would have had they been available at the time.
1997 535i V8
takes 12 volt DC as well now apparently. in principle that means you can use a battery.Originally Posted by Jehu
I really want to do something like this...when I had the motor out I was trying to find a freeze plug heater that would fit, and I didn't have any luck. I've been planning on picking up one of these generic oil pan heaters instead, hopefully before winter hits here.
LOL, try a Canadian BMW stealership or Crappy Tire (www.canadiantire.com) for the part. Shouldn't cost more than $30.Originally Posted by Mr Project
If you do install one, make sure not to overtighten the screw. It's only there to hold the heater in the block, the o ring seals it.
Anthony
03/64 production
Do you have a pic of such part which goes into the freezer plug?
As for this pad: Many BMW oil pans have cooling fins which may decrease effectiveness and may make instalation difficult.
