So the car was running fine but you decided to change injectors. New injectors apparently ran OK, but loud. Put the old ones back in, having trouble installing #6. Car immediately begins to run like ****.
So instead of replacing everything in the ignition system why not look at the last thing you messed with before the problem started, the injectors.
