Touche. I'd love to see pics of the motor in the car!
True enough but I'm running a S52 M3 engine with Turner Motorsport chip (increased redline) and a few other mods so the M5 redline is pretty much right on. It's the complete M5 tach not just the face.Originally Posted by VentoGT
Paul
Here's a pic just after I installed it last June before getting cleaned up. Not really much different than the stock M50 that's visible to the uninitiated except the M engine cover. The engine had only 50k miles and was out of a 96 so I basically had to convert it from OBDII electronics to OBDI. It uses a 95 M3 DME w/Turner chip and EWS delete coding. I've got the steel headers too but just haven't had them welded up to work yet. The stock M50 intake, throttle body, and a later vanos MAF were used to get things going. Since it's a Touring it's not as quick as an authentic M3 but it's certainly quicker than any other Bimmer wagon I've driven with the only exception being the 2003 E39 540 Touring. Now that's a hot rod!Originally Posted by VentoGT
Paul
Very cool--that must have been a lot of work to backdate the OBD on the motor...I bet there are some surprised folks when they see a wagon take off on 'em! Did you swap the 5 speed tranny over from the M3 as well?
I installed a fresh, stock type automatic (ok, shoot away). I wanted to get the swap done quickly and I just wanted a nice everyday driver not a drag racer. If I had installed the manual trans I would almost certainly dog it more and probably get in trouble. It does fine with the auto and on my first trip of any length I got 29mpg on cruise at 80mph. That's with the stock 4:10 Touring differential and it's turning about 3k rpm at that speed.Originally Posted by VentoGT
Paul
