Results 1 to 10 of 13
Thread: 540 Diff question
    Sep 2005
    Default 540 Diff question
    Ive got a 95 540 6speed. Ive found a 3.64 lsd out of a 88 735 locally and was wondering about what you guys thought on the ratio. Is this to high? I dont know the final drive ratio is so whats this going to do rpm wise in 6th cruising at 85?
    thx
    ratio aint anything, that case wont fit in your car
    Sep 2005
    Well damn it....thought it would. Are flanges wrong or is it totally wrong? I know your the diff master (read your rebuild) What do I need? I have a supercharged 540i/6 and the open diff is driving me .
    thanks for the help regal
    -drew
    you need a rear end from a 540/M5/740 etc, theres a write up in brunos site about what goes where. you'll want a better gear ratio like a 3:43/3:64 (or whatever)
    Sep 2005
    Ive look at bmwe34.net and didnt see anything....Iam I blind?
    Nov 2004
    Santa Barbara, CA
    Default less expensive option
    Your least expensive option is a S3.15 diff out of a e32 750i. Make sure the metal tag has an S in front of the ratio (3.15), otherwise it will not be a limited slip. You should be able to find one for around $300.
    The members of the M-Sport message board have tried have tried many different ratios report that the 3.15 (or 3.23, which is custom and very expensive) is the correct ratio for a 6-speed. If you go with a 3.64 it will make first gear useless, especially with a s/c.
    BTW - I can also confirm that the 735 case size is too small for your car.
    Good luck!
    Quote Originally Posted by dbals
    -drew
    USA
    3.15 for supercharged.
    3:15 from what he has is not much of a change, a lower 1st gear even tho it wont run long before a shift will really get these sleds going fast in the city range.
    3:15 from what he has is not much of a change, a lower 1st gear even tho it wont run long before a shift will really get these sleds going fast in the city range. Believe me I thought the 3:64 was way way too big bit 1st still runs til 40mph.
    USA
    well, a stock 540/6 has a 2.85 or something, 3.15 would increase engine speed by 10%, 3.25 (supposedly optimal for stock engine 540/6) by 13%
  1. Diff Question
    By BMW For Ever in forum 5 Series BMW
    Last Post: 04-05-2010, 06:15 PM
  2. e39 diff question
    By motuman in forum 5 Series BMW
    Last Post: 10-17-2009, 09:03 AM
  3. Question About Diff Swap
    By BMW_Noob in forum 5 Series BMW
    Last Post: 09-04-2008, 03:00 PM
  4. E34 LSD diff oil question
    By Rory525 in forum 5 Series BMW
    Last Post: 07-25-2006, 05:13 PM
  5. Diff question
    By Torque in forum 5 Series BMW
    Last Post: 12-18-2005, 06:07 PM
