Thread: Auto transmission noise when cold
    Sep 2006
    Perth, Western Australia
    Default Auto transmission noise when cold
    Hello I have just change the transmission fluid and have noticed a strange wining noice for a couple of seconds when the car is cold.
    Start the car and reverse out of the drive way with no problems. The drive off and then transmission noise for a couple of seconds and then it goes and does not come back for the rest of the day but happens every morning since changing the fluid.
    Any ideas.
    Are you meant to blead the fluid after a change. I put 5.5 liters of oil in there! very expensive but no choice as the pan had a small leak.
    Chicago
    Did you install a new filter as well? The filter must be the OEM one made by Filtran or else you will hear a "buzzing" sound from the fluid, especially when cold during gear changes.
    _
    Sep 2006
    no did not change the filter
    Sep 2006
    do you think it's the filter then?
    Jul 2005
    Toronto Canada
    I had the same noise but in the summer (july)....changed fluid, gasket, and filter
    no more noise and shifts alot "smoother" since then....
    all techs I asked told me same... noise is from fluid trying to get thru clogged
    filter bubbling up and forcing thru the crud (so to speak)
    dablack
    92-535
  1. ticking noise, worse when cold...rings?
    By beetos in forum 5 Series BMW
    Last Post: 07-08-2007, 05:21 PM
  2. Auto transmission noise problem 1990 535
    By Gary535 in forum 5 Series BMW
    Last Post: 07-13-2006, 06:36 AM
  3. Bearing noise when cold
    By simon-york in forum 5 Series BMW
    Last Post: 05-15-2005, 03:25 PM
  4. Loud buzzing noise after cold start. 93` M5
    By NH004 in forum 5 Series BMW
    Last Post: 04-09-2005, 11:29 AM
  5. e34 cold noise
    By nariusb in forum 5 Series BMW
    Last Post: 01-29-2005, 05:57 PM
