I have been bitting my tongue for 24 hours and I just can't do it anymore.
The psych major emerges. "You feel nothing". "Your blower stopped blowing."
Those shound like problems for a psychologist, not mechanics.
Do i need a new Brain?My blower has stopped blowing. It has for a while been growing more intermittent but today it quit for the longest and hasn't come back yet.I checked the fuses,all good.The lights in the temp dials work as usual but the lights in the three left hand buttons to turn on the rear defrost,a/c and recirculate don't.I recently changed the cabin micro filter and am aware the climate control brain is situated down there.Is that likely the culprit? Does the whole unit croak or can it be refurbished.If the fault could lay elsewhere, where else can i hunt.
1995 540i Manual build 1/95
You have an open couch?Originally Posted by Gayle
btw. its blowing again ,only a/c isn't cold.... i guess heat/water valves...
Originally Posted by Jehu
At least it is not a bad time of year to be having a/c problems. I wouldn't want to be having heater problems living in New Hampshire going into winter.
it's called a sword
Look at my production date.I do not have the sword in my car.
find it and you can test the modual and blower from the terminal.
http://www.bmwe34.net/e34main/mainte...ical/sword.htm
learn something new every day. when did they stop using swords?
that's a good thing as you are sword-averse... is there a sword in your merkhaba?
careful with that knife
