Depends on the wheel offest.
Can I run 235/60/16s on my rear tires until I can get the cash to put the 225/55/16s on em?
FS: PBR Deluxe rear brake pads [new]
I think this is a bad idea as the theoretical diameter of the 235/60 is 688.4mm and that of the 22/55 is only 653.9mm.
This means that :
1.
edit : oops hit wrong button
'90 535iSE Auto (AE+EAT) 123k miles
'86 F288 69k miles
'06('89)- PGE 2.0DOHC Turbo
'03 A160LE 19k miles
1914 Stellite E2A (no odometer!)
(+ others I daren't mention here)
www.pyghtle.com
This means that :
1.
edit : oops hit wrong button AGAIN
'86 F288 69k miles
www.pyghtle.com
I think this is a bad idea as the theoretical diameter of the 235/60 is 688.4mm and that of the 225/55 is only 653.9mm.
This means that :
1. your speedo will read 5% under
2. the gearing will change your acceleration
3. the ABS may well have issues with the front/rear disparity
'86 F288 69k miles
www.pyghtle.com
