Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: M60: quick intake question so I can get the manifold off
    Albany, NY
    Default M60: quick intake question so I can get the manifold off
    I've got everything disconnected and the manifold is loose. Only problem is I can not get the throttle cables off. The T30 torx screws that hold the bracket onto the manifold are not coming off. Is there any other way to get the throttle cables disconnected?
    I'm on my lunch break, hopefully someone can help me out. Thanks!
    Gainesville, FL
    I had to use Vice-Grips to tear the stupid torx screws out of the TB. They were a bitch and a half. I think i spend a good hour or two with vice grips trying to get them all off. Once you remove them go to homdepot and buy some standard metric bolts to replace them. next time it'll be 100x easier to remove.
    only two ( i think) torx botls hold the bracket for the throttle cables on, you just have to get those two off and you're set.
    Quote Originally Posted by brosher
    ditto with the little vice grips.
    Albany, NY
    Got one of them off but my mini vice grip wont dig into the other one. Grrrr. I gotta go to the hardware store and pick up some new hose clamps anyways. Someone stripped the crap out of the clamp screw-heads over tightening them. Maybe I need bigger vice grips.
    I dont remeber vividly but are you able to turn the bracket with one bolt out? Might be able to break the other one loose.
    East Brunswick, New Jersey
    The throttle cable can be removed without having to remove the bracket.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    what he says
    Quote Originally Posted by yaofeng
    Albany, NY
    WOOHO it's off!
    I got some better vice grips from the hardware store and they cracked it off. The mini ones I had were like $1.50 from walmart and the bolt was rounding ff the vice grip. The better ones cracked it off in a minute. Don't cheap out on tools! Made in china vice grips = suck, MADE IN USA = .
    WOOHO it's off!
    Does it make you like the hex head bolt better now? I hate the allen head and torx head bolts.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Albany, NY
    Pretty dumb, I spent a few hours on those stupid things. Really turned an easy job into something difficult and frustrating. Even had to use the dremel on one that the vice grips destroyed.
    Tomorrow I'm doing the coolant pipes and valley gasket. Hopefully everything goes back together smooth *fingers crossed*. I've got an antsy better half who wants me to be tiling a bathroom this weekend, not working on my toy!
  1. m50 intake manifold
    By shadowpuck in forum 5 Series BMW
    Last Post: 03-09-2008, 12:39 PM
  2. Intake leak under manifold Question
    Last Post: 03-07-2006, 08:17 AM
  3. Replies: 7
    Last Post: 02-15-2004, 01:31 PM
  4. Replies: 7
  5. Why would there be oil in the intake manifold?
    By Anton CH. in forum Engine & Drivetrain
    Last Post: 02-14-2004, 09:12 PM
