Results 1 to 3 of 3
Thread: E30 m20b25 engine into my e34
    Default E30 m20b25 engine into my e34
    here goes,
    does anyone attemp this convertion b4? the b25 block that i hv from e30 doesnt seem to fit well with the mounting bracket. the holes are different in position so i cant use my e34 bracket. any ideas. i dont wanna revert back to the b20 since the engine is already out.
    baton rouge, loserana
    it's exactly the same engine you just need to use the e34 mounting brackets, the e30 oil pan works, if you don't want to plumb in the oil cooler that the e30 uses the adaptor will be in your old block, unscrew the oil cooler adaptor and the threaded part from the old block screws right in
    thats wht i tot, but the old mounting can be screwed into the new block since its not alligned, the bracket is smaller. weird but its true.
  1. M20B25 head gasket on M20B20?
    By BillM in forum 5 Series BMW
    Last Post: 01-06-2011, 02:43 PM
  2. jumping the starter on a m20b25
    By ahlem in forum 5 Series BMW
    Last Post: 11-23-2009, 02:25 PM
  3. Which is working combination for M20B25?
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 01-27-2005, 06:25 AM
  4. M20B25 offer without warranty frm a junkyard..good?
    Last Post: 12-18-2004, 10:29 PM
