these are just complete guesses, but as no one has chimed in yet, food for thought.
coil packs- make sure you have spark to all cylinders.
slack in timing chain or belt
bad gasoline or bad air fuel ratio
beyond that I am stumped.
M42 - when i rev it past 4k RPM, it stumbles and the revs oscillate from 4000-4200 RPM very quickly, if you are in gear the car jerks badly forward and brakes - engine literally stumbles. Happens at any speed in any gear.
What would be the case for that? Does anyone know?
-Thanks, Artem
The chain one would be realy bad, may need to accelerate in terms of acquiring a new tensioner. I put the "plus fuel in there - 89 octane" Would that be bad for it? I am almost certain it had issues with the Premium as well.
I can also clean the coil packs, but the car seems to run very smooth othervise - smoother than my E34 when it was missing on a cylinder.
I really didnt want to do anything to the car until in about 2 weeks, but I need to figure this out - i dont want to kill the engine right away. I wanted to refresh it later, swap everything and ll flids, etc.
Slithly OT: Anyone has cool rims foe sale that fit the 4x100 bolt pattern? With new tires hopefully I need to get new tires, but it will cost me around $200 altogether, I was hoping to get a new set of rims with relatively new tires for that much.
-Artem
Also - the fuel delivery seemed like the most obvious problem to me, I think the engine just refuses to rev past that often.
Also the car sounds pretty loud.
(If all that helps)
-Artem
not sure about the rev issue like I said, but you may want to check your nearest big citys craigslist for wheels, I have seen alot of great deals on there in chicagoland.
Thanks man I will do the CL thing about the wheels - havent seen any good ones there lately though.
I know i need to give the car a tuneup but just how long can i run it with the problems... That I do not know. Wish i did
I would really hate the engine to break on me somewhere halfway before the break..
-Artem
Does it happen at partial throttle or only full throttle? Sounds like you might be running very rich. Did you recently make a change or did it just start happening?
I just got the car and it started happening as soon as i got it - so I dont know.. It happens at full throttle. (Full throttle only)
-Artem
change the fuel filter(s) and if the problem persists check fuel pressure
Will do asap - fuel filter is easy.
If the test tmr will go well, i will go it after the test tmr.
-Artem
