manual if you plan on working on the car yourself.
It will save you a lot of time and busted knuckles
Hi guys. Just bought my 1993 525i 5-speed last weekend. Very nice car.
Want to change the tranny oil, but having trouble figuring out what to put in it.
I have searched here, BF.com, and bmwe34.net without any luck. Would much rather search and find the info now than have to wait for responces.. but no luck.
Do I put ATF or Gear Oil in it? Also, thought I remembered reading a guide on how to do this at one point, but for the life of me cannot find it.
Thanks a ton for the help.
Ash
ATF. There is a drain plug and a level plug. Both are 17 mm. So you don't need to know how much.
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
I have a bently on order.
OK, so ATF. Have heard good things about Syncromesh.. Any opinions?
Also, a pump is needed to pump the fluid into the tranny correct?
with lots on hose on both ends, not the one the screws on to the bottle.
That way you set the bottles in a row and just move the hose as you filler up.
ATF fluid in a standard transmission? Enlighten me on this one...
95 E34 540i6 M Sport - 94 E34 530iT B40/6 - 92 E34 525i5 M52/OBD2 rip
It is on the label affixed to the gear box, on both the 5 speed and the 6 speed.
'01 540it, 6/01
'10 535ix. 9/09
'10 mini 6 speed
ATF in a manual gearbox does seem weird to me, but I am new to BMWs.. so.. OK..
It is a common ZF/Getrag thing, but not in most cases. A lot use heavier gear oils.Originally Posted by acidfire52
OK, is there a perticular ATF I should use??
The NAPA around the corner sells Royal Purple.. Should I use that? And what type? Dexron 3??
THanks, you guys are great.
