Results 1 to 10 of 13
Thread: corrections to secret OBC codes
    Default corrections to secret OBC codes
    http://home.iae.nl/users/bts/obc.htm
    Kai from the German E34 board informed that these are not correct:
    1. #06 is not "Amps", it's the measured current fuel in tank (in litres). Works only if ignition is on.
    2. #07 is not "% of full", it's the calculated (!!) current fuel in tank.
    3. #09 is the current voltage at terminal 15 (not terminal R!), so you have to turn the ignition on.
    4. #10 has absolutely nothing to do with something like speedometer correction, it's for the range calibration.
    USA
    range calibration!
    i need that bad, it says i have like, 580miles after a fillup, but..... thats just not possible unless im getting almost 30mpg ALL THE TIME!
    Nov 2005
    Los Angeles, near Torrance
    Thanks for the link!
    Maryland
    Thanks for all the info.
    My 540 will not respond to a "stomp test."
    Is there another way for me to find out why my check engine light keeps coming and going?
    Cheers,
    Evan
    Jan 2005
    Melbourne Australia
    Quote Originally Posted by Evan
    Cheers,
    Evan
    Same Problem with the check engine and stomp test.
    "Bump"
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    WOW, Built in speedo calibration!!!
    I never knew one could use it to calibrate the speedo.
    Does anyone have non-stock sized wheels on their e34??? Have I been missing something???? Why don't we rant and rave about this?
    Quote Originally Posted by genphreak
    WOW, Built in speedo calibration!! Have I been missing something???? Why don't we rant and rave about this?
    Cos someone dosen't read posts proeprly i guess. Doh!
    I'll have to try this function out so will let you know Erich. Nick
    Sep 2006
    South Africa
    Heya Shogun ... so you're saying we cannot calibrate our speedo? Damn I wish I could do that, but thanks for the codes and corrections. Good info!
    Sep 2006
    South Africa
    Can we "program" these new codes into our dash display to bring 'em up when we press the turn indicator stalk - so that they're always available? Just too lazy to try, so thought I'd ask.
    Australian cars do not have a possibility for a stomp test, only U.S. specification cars.
    But you can do that by adding some wires. I have once posted that.
    MOTRONIC to cluster and installing the bulb in the cluster. Wiring depends on the MOTRONIC, and not all years of production possible.
    I only have the details for the M70 V12 MOTRONIC.
  1. BMW stomp test blink codes fault codes
    Last Post: 11-12-2009, 10:53 AM
  2. OT: E32 V16 - the secret 7
    Last Post: 03-11-2009, 11:52 PM
  3. What's the secret to get the guibo off?
    By bfons in forum 5 Series BMW
    Last Post: 06-12-2007, 09:18 PM
