Results 1 to 7 of 7
Thread: indicator relay
    NW UK
    Default indicator relay
    hi guys,
    aoplogies if this is a daft question but i'm getting conflicting info from the web and the searches i've done on this site
    my e34's a uk 525
    where is the indicator relay
    i belive its next to the lkm in the engine bay but am also told it's underneath the steering wheel cover under the dash (i can hear something ticking in the car when the indicators are on) or are there actually two!?
    regards
    sam
    NW UK
    ok found it next to the lkm
    so whats making the clicking inside the car??
    please cure my curiosity on this
    regards
    s
    USA
    is there a secondary relay for the rear lights?
    NW UK
    oo maybe?
    anyone know if there's two?
    if it's only the one in the fuse box then what the hell is that ticking behind the dash when the indicator/turn signals are on
    s
    Feb 2005
    Nowra NSW Australia
    Only one, its a dual relay 'left and right' and will be in the fuse box under hood. Can be renerred useless when shorting live wire when installing clears on rear! Ask me how I know this. $184 in Aust $23 from BMA.
    Default The audible turn signal relay is, as you were told under the
    lower steering column cover right next to the ignition switch. If you remove the lower steering column cover you can see it.
    Quote Originally Posted by bigtallsam
    hi guys,
    my e34's a uk 525
    regards
    sam
    NW UK
    thnaks guys!
  1. Replies: 8
    Last Post: 07-02-2006, 07:58 PM
  2. M50 coils, main relay or fuel pump relay?
    Last Post: 05-31-2006, 07:48 PM
  3. Which Relay is Fuel Pump Relay (PIC)
    By Jim525it in forum 5 Series BMW
    Last Post: 03-19-2006, 08:43 AM
  4. indicator
    By frankie 525i in forum 5 Series BMW
    Last Post: 03-14-2004, 08:08 AM
  5. indicator
    Last Post: 03-14-2004, 07:57 AM
