Results 1 to 4 of 4
Thread: Brake Bleeding With ASC
    Default Brake Bleeding With ASC
    I have searche the forums and found only one article related to my question but there was no follow up on it, so my question is can I bleed my brakes with a pressure bleeder, or do I have to take it to the stealer? If so will my ABS and ASC get all messed up? Thanks for the help guys appreciate it.
    USA
    it is kind of interesting that i couldnt find ANYTHING about bleeding ASC cars either.
    i ended up NOT using a pressure bleeder, but did use speed bleeders, and so far its not giving me any problems.
    do the front, then the back, then the front again, right to left.
    No problem using a pressure bleeder.
    Knoxville, TN
    My partner and I used the pump and hold technique. Did not touch ASC and have had no problems. ASC works perfectly as do the brakes.
  1. brake bleeding problems..........
    By duckloads in forum 5 Series BMW
    Last Post: 03-02-2008, 05:27 PM
  2. Need Some Brake Bleeding Advice!
    By infinity5 in forum 5 Series BMW
    Last Post: 06-29-2005, 06:01 PM
  3. The BMW Brake FAQ, bleeding, shimmy etc
    Last Post: 04-09-2005, 07:58 AM
  4. HELP! Brake bleeding problem
    By Ted K in forum 5 Series BMW
    Last Post: 10-24-2004, 12:41 PM
  5. Brake bleeding on a 540i with asc.
    By wengenstein in forum 5 Series BMW
    Last Post: 09-15-2004, 05:33 AM
