Results 1 to 4 of 4
Thread: 1995 525i runs rough at startup
    Sep 2006
    Edmond, Ok
    Default 1995 525i runs rough at startup
    I have a 1995 525i- When I start my car in the mornings it runs rough until it warms up and then it purrs like a kitten. Any advice on why it would run a bit rough from a cold start?
    Aug 2004
    RTP North Carolina
    Default lifters
    The lifters being hydraulic need time to pump up. My wife's 93 525ia had the same issue. I switch to 0w-40w oil and the problem went away.
    USA
    get some Auto-RX... and check for intake leaks when cold.
    Aug 2004
    RTP North Carolina
    Default Also check the crankcase vent hoses
    It's a pity to attach back to the throttle body. The excessive heat turned the rubber in crap. It's part 5 on the picture..
    http://www.realoem.com/bmw/showparts...84&hg=11&fg=15
  1. M60 Rough idle, blue smoke puff on startup
    By bimmo_2007 in forum 5 Series BMW
    Last Post: 02-16-2010, 03:58 PM
  2. runs rough cold
    By Ryan12345d in forum 5 Series BMW
    Last Post: 08-02-2008, 09:16 PM
  3. 1992 525i project runs rough
    By wiebuschk in forum 5 Series BMW
    Last Post: 12-19-2007, 06:15 AM
  4. runs rough
    By jippijak in forum 5 Series BMW
    Last Post: 03-06-2006, 06:48 PM
  5. White cloud and rough idle at startup.
    By NielsGalan in forum 5 Series BMW
    Last Post: 10-04-2004, 02:43 PM
