Results 1 to 7 of 7
Thread: transmission will not shift.
    Aug 2006
    Default transmission will not shift.
    Hi I have a 1989 525i that has been in a pretty good mechanical condition until this morning. I have not started the cars in four days, and when I tried to move the car this morning, it will not reverse nor go forward. The gear selector does go to all the different positions and is indicated on the dash board, but the car will not move. PLEASE HELP.
    Jun 2006
    Bradenton, FL
    Check the linkage at the transmission. Near the front of the tranny on the left (driver's) side. There is a spring clip that holds the arm to the linkage, and that usually comes off over time. Shouldn't be too expensive to get fixed.
    USA
    can you get it into neutral? if not its probably the linkage.
    Aug 2006
    Quote Originally Posted by Reckless_Kelly
    Thanks! I will check that first thing in the morning.
    Aug 2006
    Quote Originally Posted by BillionPa
    It does go into neutral and every other gear but which ever gear that I put it into, the car does not move. Every other gear acts like the car is in park or neutral.
    Derbyshire, UK
    Quote Originally Posted by pHoff
    If it's a failed linkage, that's probably because it is in park or neutral. Can you push the car in any gear? If not, it's stuck in park.
    1997 535i V8
    USA
    could be the EH clutch unit froze.
  1. Replies: 9
    Last Post: 03-03-2011, 05:34 PM
  2. Replacing shift cable on auto transmission
    By Phil F in forum 5 Series BMW
    Last Post: 12-14-2006, 05:14 PM
  3. auto transmission mis-shift
    By sgeorge in forum 5 Series BMW
    Last Post: 11-04-2005, 05:50 PM
  4. Change transmission fluid for stick shift?
    By unhygenix in forum 5 Series BMW
    Last Post: 12-27-2004, 01:37 PM
  5. whalen shift knob short shift combo - E39 2000
    By peffer in forum 5 Series BMW
    Last Post: 09-13-2004, 11:41 AM
