Results 1 to 5 of 5
Thread: will an E30 M-Tech steering wheel fit an E34?
    Apr 2005
    DC
    Default will an E30 M-Tech steering wheel fit an E34?
    Found an M-Tech wheel off an E30....would there be problems fitting it? I have an air bag steering wheel. Should it be easy to disconnect and install the new wheel? It looks like this :
    schnell944
    Nov 2005
    Default might fit
    ..be hard to stuff an airbag in there tho..
    Quote Originally Posted by schnell944
    Adelaide, Australia
    That is the steering wheel on my '89 535i, pull off you wheel (CAREFULLY) and see how it bolts on.
    That one there slides over a threaded shaft and then you tighten up a nylock bolt and washer over the top.
    11/88 535iA
    That is the wheel I ust removed from my 89 535is, so should go on fine. You should try to finding the Mtech 2 one though, looks alot better.. imo
    Philly, PA
    Yup, that will fit 89-90 E34s. I think 91s got the newer column. I have an M-Tech II. They are getting cheaper and cheaper on Ebay btw.
  1. M-Tech 3 Sport Steering Wheel
    By Sam-Son in forum 5 Series BMW
    Last Post: 04-25-2007, 03:55 AM
  2. M Tech II steering wheel wear
    Last Post: 10-03-2006, 06:50 PM
  3. BMW M-TECH II STEERING WHEEL EVO available in Canada...
    Last Post: 09-11-2006, 09:03 PM
  4. M-tech 1 or M-tech 2 Steering wheel
    By Felixdacat in forum 5 Series BMW
    Last Post: 04-19-2006, 02:28 PM
