Results 1 to 9 of 9
Thread: My speedo stopping working?
    Melbourne, Australia
    Default My speedo stopping working?
    This morning when I left for work I noticed my speedo indicator was not working.
    Correspondingly the odometer and the ODB's KM's remaining were also stuck in a time warp. After I'd travelled about 5kms everything came back to life.
    It was fairly cool this morning around 5 celcius. I'm figuring either something temperature related or a loose connection between the speed sensor and DME.
    kingsbridge, devon, uk
    i had a simalar problem when i changed my engine, i left the gearbox in place and didn't disturb anything , when i took it out for a test drive the speedo wasn't working, but when i drove it the next day it was fine and has been scince, weird
    Aug 2006
    Portugal
    could be the 2 condensators in the instrument cluster, i had the same problem, changed them and everything is working fine since, i think on the site of Shogun you can see how to do it.
    capacitors, my friend.
    Get out the soldering iron.
    40 minutes and it is done.
    Aug 2006
    East Tennessee
    Could I be having the same problems with my '86 535i?
    Aug 2006
    Portugal
    oeps, yes, the capacitors, and don't forget to disconect the battery, i did forget it and had to reset the car to get rid of the airbag control warninglight on the dash.
    You should always disconnect the battery when working on the electrical system ofcourse.
    My car did'nt " bong " or made any other noises , the speedo just did'nt work properly
    Default Did the chime go bong the first time you hit the
    brake pedal after starting the car that morning? If so then it is probably the capacitors as others have suggested, I would check the connection at the speedo sensor back at the diff, if it was that cold then its possible that it was a bad connection.
    Quote Originally Posted by pundit
    Did the chime go bong the first time you hit the brake pedal after starting the car that morning? If so then it is probably the capacitors as others have suggested, I would check the connection at the speedo sensor back at the diff, if it was that cold then its possible that it was a bad connection.
    Nope... no bongs... or even gongs for that matter!
    Has worked fine since.
    Hockinson, Washington
  1. Car shutters in reverse, stopping
    Last Post: 06-09-2012, 06:04 PM
  2. M30 dies when stopping periodically
    By Asamaan in forum 5 Series BMW
    Last Post: 05-07-2010, 01:42 PM
  3. ot: not speeding and not stopping
    By timandbim in forum 5 Series BMW
    Last Post: 10-16-2007, 01:04 PM
  4. Gauges stop working, Fuel, speedo,temp,etc..
    By houndjjj in forum 5 Series BMW
    Last Post: 06-21-2006, 03:43 AM
  5. e34 speedo not working!!!!!
    By crisc77 in forum 5 Series BMW
    Last Post: 07-27-2004, 05:13 PM
