You might need to get your valves re-adjusted.
http://bmwe34.net/e34main/maintenanc...lve_adjust.htm
i got a 1990 535i with 135K. the ticking is so horrible. during acceleration it sounds like a lawn mower. idling it sounds like a muscle car. what can be the problem? thanks
Greg Mannino
Exhaust manifold leaks will do that too. Check the downtubes for leaks also.
gale
umm i do notice that my exhaust has this popping effect. when i put my hand in front of the exhaust i would feel the air sort of popping? like a put...put..put sort of effect.
top end getting enough oil?
If there aren't any leaks, with the engine running, cover the exhaust tips with the palms of your hands (use a rag, they get hot), and you should be able to stall the engine. If there is a leak, you'll hear a whooshing sound where ever the leak(s) are.Originally Posted by 535ibimmer
gale
Does it sound like it missing? might want to check your timing and you secondary.
I'll bet it only comes from one spot on the valve cove( use a long handled screw driver and touch the cover and listen throught plastic end)just adjust your valves down to 9thou...I'll bet you have a worn spot on you came somewhere
