shift through all of the gears and then put it in park idleing and pull the fill hole plug and check it as you would a manual transmition.
Hi,
Is there a way to check the transmission fluid level on a M50 with Auto tranny.
I checked the Bentley and it lists nothing.
I have noticed that when i put the car in reverse or Drive in the morning I have to press on the accelerator for the car to start moving. It does not roll as it did on my prev M20
Also i have a kind of Jerky motion when the car changes gears. Is it the fluid or the Subframe bushings.
Many Thanks
Steve
Thanks Pyro. I am trying to find the fill hole plug and cant seem to locate it. Am i loosing my sight or what!!!Originally Posted by pyro
on the side of the rear pan
Thanks will check it tonightOriginally Posted by Ross
must be level and about 100 degrees and idling.
