Results 1 to 10 of 12
Thread: Temp gauge..odd showings..
    Aug 2006
    Denmark
    Default Temp gauge..odd showings..
    Hello all
    My first post here... great forum by the way.
    My temp gauge is showing some odd readings. When i start my car (from cold engine) the temp needle jumps straight way to 12 o'clock and works its way to 2 o'clock as engine getting warmer.
    When i disconnect the coolant temp sensor it shows Zero. Then laying the sensor at a hot spot on the engine it straight away jumps tp 2 o'clock again.
    Im i dealing with a faulty coolant temp sensor here ? Its getting pretty funny to drive without knowning how hot your engine is.
    Anyone else seen that kind og error before?
    my car is the bmw e34, 2,5 - 1988
    Regards
    /Anders
    Boston & Attleboro MA
    Possible instrument cluster issue, find out if your SI board has batteries that tend to fail after 15+ years.
    http://www.programainc.com/files/03_...t_Clusters.pdf
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    possible yes, I would replace the sensor first.
    order parts from www.bmaparts.com
    Quote Originally Posted by DaCan23
    E34 do not have SI batteries anymore like the older models E30 and E28.
    They have capacitors.
    But capacitors also fail after 15 years or earlier
    http://bmwe32.masscom.net/johan/dash...dash_caps.html
    Aug 2006
    Denmark
    might have to say the problem was showing after i replaced my top during overheating... i gotta new top and also replaced the rest above the top...
    The rest og my gauges works fine..
    Honolulu
    Default The M20 has two sensors
    on the water neck.
    Could they be mixed up?
    Aug 2006
    Denmark
    No the cylinder head gasket was replaced because the old one blowed... then i also got a new air intake manifold, tstat housing and so on,,, engine parts where taking from en e30 m20 2,5 1988. So got all new gear from a e30 engine from the head gasket and above
    Aug 2006
    Denmark
    Blitzkrieg Bob:
    I will look that up.. and try to look for them to possible be switched
    and because af the gague failure i also constantly getting messages that engine is overheating... very very irretating
    Honolulu
    Default There was a member here last year
    who went through something like this and after all the work, it turned out to be mixed up high temp and low temp sensor on the water neck T stat housing.
    Good luck
    Aug 2006
    Denmark
    Blitzkrieg Bob:
    Can u tell the line up by color... i know one og them are blue and i think one og them are brown.. is it the two most outer sensors we are talking about?
  1. Wobbly temp gauge
    By NielsGalan in forum 5 Series BMW
    Last Post: 11-09-2009, 06:44 PM
  2. help!!temp. gauge
    By bmwrp8 in forum 5 Series BMW
    Last Post: 08-06-2008, 03:36 PM
  3. Temp Gauge Straight Up?
    By JMI in forum 5 Series BMW
    Last Post: 12-21-2007, 06:51 AM
  4. Temp gauge problem
    By MikeyMike in forum 5 Series BMW
    Last Post: 08-27-2006, 11:27 AM
  5. Oil Temp/Press & Water Temp Gauge Install
    Last Post: 06-26-2006, 01:25 PM
