Results 1 to 10 of 11
Thread: Your Advice Wanted -- Shocks/Springs/Steering DIY
    Maryland
    Default Your Advice Wanted -- Shocks/Springs/Steering DIY
    I'm about to start removing my shocks, springs, and steering components.
    The replacements are Lemforder, H&R springs, and KYB shocks.
    If you've done this job yourself can you offer me any tips or tricks that will make my week go easier?
    Are there any parts you found you needed in the middle of the job so that i can order them now?
    Cheers,
    Evan
    T·O·R·O·N·T·O
    - presoak in some PBBlaster to prep for strut removal.
    - something to cut or grind down bump stops (depending on height drop)
    - unless you mated the KYBs with the H&Rs... spring compressor
    Next!
    ball joint removal tool.
    Yes, as Qube says PB Blaster is tour friend.
    Remember to let the car down before snugging up the through bolts for the thrust rods. This prevents them from being preloaded all the time and failing prematurely.
    Since you are doing it all at once it goes pretty easy. Grab a six (twelve?) pack and get dirty.
    Jul 2005
    Mississauga, Ont.
    I recently did mine (replaced all front arms, struts, hubs with OEM).
    The hardest parts for me:
    - poping the balls joints (broke 2 ball-joint removal tools)
    - removing/tightening the top nut on the strut (i have the EDC III and the nut is recessed).
    ... then of course there was the fact that i put in a washer upside down and had to take the strut out, apart, flip the washer, reinstall - DOH!!!
    http://www.realoem.com/bmw/showparts...32&hg=31&fg=10
    Part 8 is a bevelled washer.
    Dec 2005
    I just finished replacing the front end on my 525 this last weekend. Hardest part was removing the ball joints. I wish I had went to Advance Auto first before trying to remove them by pounding to death with hammer and forks. They had a free rental with about five different types of pullers. I picked one out, tightened it up, struck the part of the tool over the threaded portion of the ball joint twice and it popped right out. Send me a private email with your email address and I'll send you some photos of the tool. I couldn't believe the difference after I was done with instaaling all the new components.
    East Brunswick, New Jersey
    If you haven't got the air compressor and a set of air tools, get them now. You'll say to yourself, "why didn't I get them earlier?"
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Maryland
    I have air tools so I'm confident about being able to get everything apart no problem.
    I'll be taking photos of the whole process for the board. Thanks for any/all advice.. it helps a lot.
    Evan
    May 2006
    Hampton, Vic
    How much do the bump stops need to be cut down by? Is it just the same amount that the car has been lowered? I recently put eibach springs and koni shocks in the front of my car, but it bottoms out occassionaly, but I didn;t cut the bumpstops, could this be causing it?
    John
    Pics of my E34 M5 -> http://www.jrobbo.com/M5
    Melbourne, Australia
    Quote Originally Posted by jrobbo
    John
    I'm about to fit Eibach Prokit springs and Koni sports dampeners all round to mine along with new upper & lower arms (Lemfoder), tie rods, centre link, sway bar links, spring pads, bump stops... yada, yada, yada.
    I bought new bump stops which I'll cut down by 1.5" which is the amount of drop the Eibachs give at the front and 1" at the rear.
    Incidently how does your M5 ride with the Eibachs and Konis?
    As mine had factory sports suspension with tired shocks and front end, I'm actually expecting a slight improvement if anything.
  1. KYB GR-2 shocks and Vogtland springs
    By Dave PA in forum 5 Series BMW
    Last Post: 08-24-2007, 05:59 AM
  2. Used M5 Frt/RR Shocks and Springs
    By TheDuke in forum 5 Series BMW
    Last Post: 12-02-2005, 12:51 PM
