Results 1 to 8 of 8
Thread: Rotors for 540i - Sport??
    Frisco, TX
    Default Rotors for 540i - Sport??
    I was getting ready to order new pads and rotors for my newly acquired 540i. I noticed that there are different rotors for a 540i “Sport”. How do I know if I have a sport model? The car has the M Sport Suspension. Does that mean I need to order the Sport rotors?
    Thanks in advance.
    May 2005
    central coast nsw au
    to be honest I really think oem is the best. I have never thought that there was any differance. i must admit that i am not compleletly knowlegdeable about these things. It is a six speed? or an auto?
    I have to say that at the end of the day i dont really dont go in for spending heaps on performance **** because i drive it every day, every week, heaps of miles and oem spec seems to do quite well.
    where ur at might make a differance cause if u have one of the last of the run models with all the goodies stacked on it would change the spec. 540i( but M) is a differant spec depending where u are)!
    Try realoem.com to see whats the go
    best of luck. hope some other fuka with a bit more knowledge can help u.
    Apr 2005
    So Cal USA
    you will not have a m-sport suspension unless the car is a M-sport.. There is electronics to control the damping
    95 M-sport SOLD now NSX
    run the last 7 digits on realoem.com and get the correct part number and then order the rotors and pads.
    Frisco, TX
    Thanks guys. I checked out realoem.com but it doesn't help. They still list two different part #'s for the rotors:
    02 BRAKE DISC, VENTILATED 302X28 2 34116756090 $122.76
    ONLY APPLIES TO
    INDIVIDUAL SERIES 95 540I SPORT
    02 BRAKE DISC, VENTILATED 315X28 2 09/1995 34112226385 $103.23
    I guess I can just measure what is there and figure it out that way.
    ya, youll see 13mm...
    Quote Originally Posted by zman-95-540i
    Thanks in advance.
    What's the build date, and does the car have an EDC button on the dash?
    -Trevor Ely
    '88 535is
    '95 M Sport 540i (1 of 200)
    '91 M5
    USA
    the sport one is for M5 front brakes, just take a ruler to your rotor to find out its diameter
  1. 540i M-Sport
    By Jr ///M5 in forum 5 Series BMW
    Last Post: 02-21-2009, 07:07 AM
  2. 540i M Sport?
    By BFEINZIMER in forum 5 Series BMW
    Last Post: 03-27-2008, 11:59 AM
  3. 540i M sport
    By mastnra in forum 5 Series BMW
    Last Post: 10-29-2006, 10:49 PM
  4. How to replace 540i front brake pads and rotors
    By Cambridge in forum 5 Series BMW
    Last Post: 07-08-2006, 05:39 PM
  5. Wow! That '95 540i/6 M-sport on E-Bay went for.....
    By Brian C. in forum 5 Series BMW
    Last Post: 02-25-2004, 12:10 AM
