you are correct they will be rhd the cut off will be \___ instead of ___/
it is possible he has LHD cos most of europe is LHD
I was about to buy some Euro smiley headlights that came off an e34 from England, but then I thought that the beam pattern would be different because they are RHD cars. Are my thoughts correct?? -Andrew
Gone but not forgotten
Yes they will be opposite more than likely but that's not a problem. You simply remove the low beam from the bracket and mount it i guess you would say on the other one or you flip it around i believe. I recall reading something about this process in the manual online for when you travel to different countries
