I thought you did yours already... this seems like a rerun... wonder who it was. Do we get better performance running a K&N there?
Finally got around to changing out the cabin filter on the touring. It was barely blowing air anymore even on high blower. After pulling it out I could see why.
It's not as bad a job as I was expecting. I'd read they can be nasty (part of the reason I kept putting it off). Wish now I would have done it much sooner. Took about an hour.
1988 M3 - Track rat
1989 325iC
1995 530iM
2000 323iT - UUC BBK, PSS9 Coilovers
2005 GMC HD Crew
First one I've done. It had been needing it for a while. Clogged filter + Houston heat makes for unhappy wife
1988 M3 - Track rat
1989 325iC
1995 530iM
2005 GMC HD Crew
if you look it you will see the date on the side and that will give you a good idea how old, they look fairly nasty after a couple years, seen a few at work that were the orignal 12 year old filter, sorta like a hunk of plywood as far as the blower is conserned
Ya, this one was dated '95 so it's been in there for a while.Originally Posted by winfred
1988 M3 - Track rat
1989 325iC
1995 530iM
2005 GMC HD Crew
Well, I know what I'm doing this weekend. I've had the filter - that gave me the incentive to change it out. I'll be real curious to see when mine was changed, because up till I bought it from my dad, the BMW dealer maintained it. Were they changed at the inspections or by customer request only?
May the Schwarz be with you...
Changed mine this spring, it was nasty. Severely restricted air flow and it was starting to stink...hardly any AC was getting thru, now it's like a deep freezer...quite nice with 100 degree heat we've has this week.
Hallelujah!
I found mine to be "only" 3 years old but nearly as filthy.
It's not my favorite job to do nor do I enjoy shelling out for the filter but will do so annually after seeing what collects in there.
where is this filter located? how do you change it? sorry for the newbie question
NEVERMIND. I FOUND THE INFO NEEDED. I'M A DUMBASS.
Hey brodee how about some fresh pics of the touring while your at it! :P
1990 Islandgrun 535iM Sedan
3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
