Results 1 to 4 of 4
Thread: AC Compressor for 89 525/535
    Laplace, LA
    Default AC Compressor for 89 525/535
    Quick question. Will the part numbers for an 89 AC compressor for a 525 and 535 the same? I guess the better question would be can I use the AC compressor off of an 89 535 on my 89 525?
    BMWCCA Member #330940
    Bayou Chapter, Louisiana
    Pittsburgh, PA
    check realoem.com to see if its the same part number for both models
    Present: Black 1995 525i | Past: Red 1989 535i; Black 1985 535i
    Honolulu
    Default If they look exactly the same
    BMW used a bunch of differant compressors. Behr, Bosch, Seiki etc. Some are indentical, and some have differances in mounts and manifolds.
    The most important things to look for are the manifolds (straight or angled) the side switch if it has one, and the mounting flanges.
    Here is a wonderful site of Denso Germany with
    Bestell-Nr.= order number
    Kompressor = compressor
    Typ = type
    Füllung = filling volume
    OE-Nummer = OEM part number (BMW)
    (nur zum Vergleich = for comparison only)
    click on Cross Referenz
    Liste
    select BMW
    Also interesting: Anleitung zum Wechseln der Schaftdichtung
    instructions to replace the seal at the shaft
    http://www.densoklima.de/frameset.htm
  1. A/c compressor oil
    By philbyil in forum 5 Series BMW
    Last Post: 09-03-2010, 06:13 PM
  2. Replies: 5
    Last Post: 07-30-2007, 08:39 PM
  3. PAG Oil in AC Compressor
    By GoldenEagleFan in forum 5 Series BMW
    Last Post: 06-06-2006, 08:01 PM
  4. e39- dsc compressor
    By tim in forum 5 Series BMW
    Last Post: 11-03-2005, 08:14 AM
  5. A/C Compressor
    By jj7 in forum 5 Series BMW
    Last Post: 03-02-2005, 09:06 AM
