Results 1 to 7 of 7
Thread: "Warped" Brake Disc + Other Myths of Braking System
    Default "Warped" Brake Disc + Other Myths of Braking System
    Best article I've read in a long time. Thanks shogun
    May 2006
    NH
    I have braking shudder.The rotors came with the car so i have no idea how how long they've been on the car but the pads were put on when i bought it a couple of months ago and as far as i can remember the shudder has been noticeable on high speed braking all along.I suppose the thing to do is swap rotors since these have probably developed the cementite problem.I don't race the car but do drive it aggressively on the highway when i can so i suppose a high performance street pad is in order .Are Brembo the recognized best over all rotors?I think I'll try X-drilled for this run so which brand pads can anyone recommend?I also read , i think on that Tire Rack shake diagnosis chart, that this shudder under braking only could also be Control Arm bushings.The car was in two BMW shops recently and neither suggested there was any need to address any front end components but could they not be cracked inside and therefore allow a lot of give yet appear intact from casual inspection? the front end is steady otherwise during all modes of driving as far as i can tell . Would failed Control Arm bushings also cause some instability at other than high speed braking?
    1995 540i Manual build 1/95
    The thrust rods on these cars are shot by the mileage your profile indicates. If you feel it in the steering wheel then replace the thrust rods(upper arms)
    May 2006
    NH
    You mean http://replacement.autopartswarehous...20Arm&dp=false these?
    try BMAparts.com but call them, the price will be better then the web site.
    edit: also mention "dot info" and you will recieve another small discount!
    tell them you want the lemforders with the 740 bushings (better)
    a high speed shake could be rotors, I have the opparts rotors, like 25 bux each without a problem.
    thrust arms typicaly show failure when you brake from 65-55 mph.
    Mar 2004
    Appleton, WI
    Don't get crossdrilled rotors, for the most part, they are a gimmick too make the car look fancier. Brembo's aren't "crossdrilled" they are actually cast with the holes already in them. I hear ATE's are pretty much the best for every day driving.
  1. Replies: 4
    Last Post: 12-31-2008, 10:41 AM
  2. Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Last Post: 10-16-2007, 07:12 AM
  3. Remote Start Alarm System that bypasses "CODE"
    By saj3n in forum 5 Series BMW
    Last Post: 10-26-2006, 04:49 PM
  4. "Disc Error" - Not so simple is it...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 07-26-2005, 04:23 AM
