EDIT: If someone can tell me the size of the two small bolts it would be perfect!
Is your rear end flailing more than you'd like? If so, take a few dollars out of your wallet and grab a pair of these...
RacingKing.ca Subframe Plates:
http://www.racingking.ca/Canada/Scri...?idproduct=693
The install is 'butt' simple and 'should' take no more than 15 minutes of even the clumsiest people. The primary install is here:
http://www.bmwe34.net/e34main/upgrad...ame_plates.htm
Of course, I'd like to go into much more detail for those that have never lifted a wrench before, but still would like to tighten up their 'rear end'.
I'd like to offer modified instructions here:
Procedure:
Socket set with 22mm
and XXmm, plus extensions for leverage
1. Remove the 3 bolts holding the subframe bushing plate.
You don't need to jack up the car to do this, unless your car is lowered and you can't see what the heck you're doing.
2. Install the bushing inserts on the plate
you removed (you don't need to remove the bushing) and place the plate back in place.
3. Reinstall the plate and tighten the bolts
but don't over-torque!. Take the car for a test drive.
Having said that, a picture says a thousand words...
Jack up the car as needed to see what's going on. Note that your jack point blocks access to the two small bolts so be smart about it
This is where the plate is fastened.
Note the two small XXmm bolts and one 22mm nut.
