Results 1 to 10 of 12
Thread: does anyone know what this BMW standard is?
    Dec 2005
    Brisbane Australia
    Default does anyone know what this BMW standard is?
    BMW N 600 69.0 - BASF
    I was looking at coolant and i found one that reckons it complies with this specification (not sure about the BASF part but anyway)
    Dec 2005
    Brisbane Australia
    so will i be struck down with the hammer of thor if i use this coolant or is that a blessed coolant of the fatherland?
    Not blessed by the fatherland but by BMW, Saab, VW, Mercedes etc.
    Do a search and you will find a lot of info. In short:
    Coolant uses in BMW must not contain nitrite and animo and phosphate and must also have corrosion inhibitor.
    Try Zerex G48, I read that is approved by BMW:
    copied:
    Coolant answer from Valvoline
    Message: Our Zerex G48 is tested and certified for use in BMW vehicles. We have other products that will protect all the parts in the engine, but they have not gone through the formal approval process.
    Dec 2005
    Brisbane Australia
    Yes erich i am aware of the low phosphate requirement of bmw however i was not familar with this standard number I was curious whether this was their standard that they require for their coolants.
    anyway
    I shall revel the mysteries of the coolant too all aussies.
    it is Castrol NF coolant and NF 50 premix
    you can see the TDS here search for coolant in the drop down menu.
    i am going to see whether i can get this coolant for my next coolant change through work, the 50 premix is 50/50 so its perfect for a top up as well! i will work out how much she costs. any australian members remember how much coolant from the dealer costs?
    Default On ya Rob!
    Quote Originally Posted by rob101
    anyway
    Dude... Shogun's link had a lot in it
    i.e. from BASF's coolant FAQ:
    Is it sufficient to go by the recommendations on the labels or packaging of engine coolants? No. Automobile manufacturers do not recommend engine coolants; they only approve them for use. You should therefore make sure that engine coolants are officially approved by the manufacturer before you purchase them.
    I think this makes it pretty clear. BMW don't issue a standard, they simply test the various appropriate coolants and specify one as part of a procurement process with a manufacturer (or several). If none of them will sell their coolant to the aftermarket recommended for your car I'd say the risk is not worth it, though I commend you on your continued research.
    Glysantin® Protect/G05
    Extremely suitable for cast engines
    Glysantin® Protect Plus/G48
    Suitable for all popular makes of car
    Glysantin® Alu Protect Premium/G30
    Recommended for aluminium engines
    Even though this is probably OK, which one would you use?
    BMW provide it in a bottle over the counter.
    I think it is something like AU$65 per 2 years... is it really worth all this effort?
    Even if you were 99% sure you could find a substitute- is it worth corroding your motor and so on if it goes wrong somehow? Don't get me wrong- ultimately if the mystery can be unravelled appropriately and a better source found, I'll be clapping and patting you on the back. But due to the way these products are marketed, it seems a hard thing to do without resorting to chemical analysis!
    Nick
    Glysantin G48/24
    of the companies BASF, Unico (South Africa) and Chang Chun in China are approved. BMW produces in South Africa and China now too.
    mixture ratio with water 50:50 (+-2,5%)
    Water requirments:
    Looks: clear, colourless
    no suspended solids/sediments/particles
    pH-value 6,5-8,0
    hardness max 20° d.H.
    Chloride-contents max. 100mg/l
    Sulfate-contents max. 100mg/l
    Jul 2004
    BASF is the mfr of BMW coolant in Europe and other parts of the world.
    In the U.S., BMW contracted Valvoline to make G-48. For a cheaper alternative, get Saab "blue" coolant. Its also G-48, but when sold with the Saab label, its more like $12/gal versus BMW's $24-30/gal.
    Quote Originally Posted by bfd
    I'l check the price of the Saab stuff and report back.
    I suspect in Oz that it'd be as much as the BMW stuff... but doesn't Volvo use the same stuff too?
    Jul 2004
    According to the Valvoline website, the following mfrs use Valvoline Zerex G-48: BMW, Saab, Jaguar, Rolls-Royce, Volvo, Cummins, and VW.
    https://www.valvoline-technology.com/data/valv/prodinfo.nsf/0/85256AE300727D2B85256FB300100795/$file/Zerex+G+48.pdf?OpenElement
    I've only investigated Saab, and found they have 2 coolants - a blue and an orange. I bought the Saab "blue" stuff.
    Actually, you may want to see what Rolls Royce uses....Let us what you find with Volvo.
  1. ot: why I don't drive a standard
    Last Post: 06-03-2010, 09:21 AM
  2. hub rings - standard size?
    By choccibicci in forum 5 Series BMW
    Last Post: 08-08-2007, 08:08 PM
  3. m5 diff in a standard 525i?
    By filip00 in forum 5 Series BMW
    Last Post: 07-16-2007, 05:36 AM
  4. What is the difference between M and standard
    By ThoreauHD in forum 5 Series BMW
    Last Post: 04-15-2006, 02:08 PM
  5. Did ALL E34s come with ABS as standard?
    By jplacson in forum 5 Series BMW
    Last Post: 03-07-2004, 01:40 AM
