rebuild your engine head, change your pistonrings.
do a engine flush, clean out the exhaust pipes. Replace all ignition parts. Do a engine flush and change oil and filter.
I dyno'd my 1995 525 end last year and it came up with the following numbers:
132 HP
143 N.m
Are these numbers acceptable (yes, the car is 11 years old) or not? It runs smooth and there are no problems I'm aware of. Big question; where do I start to "fix" the old beast. What are the major things that cause such a drastic degredation in numbers?
(I have bought an EAT chip but havent dyno'd yet, just want to know what else...)
Eurospec-12/1988-535iL-M30B35-5speed
Why do you call it a "shogun" reset?Originally Posted by Qube
Because... it's a credit to Shogun! No way... you didn't know that?
http://www.bimmer.info/forum/showthr...t=shogun+reset
we all know that, Alex is on them meds again.
[QUOTE=Qube]Because... it's a credit to Shogun! No way... you didn't know that?
if the engine has good compression and doesn't use more then a quart or so of oil between changes it's in fine shape, it just comes down to whats out of spec like a worn airflow meter or 02 sensor or old crappy injectors would be the most likely votes, other things like timing chain stretch and vacuum leaks chip away at power too, general rule of thumb is 15-20% of avalable power gets lost in the drive train through friction so that takes it into the 150-160 range from stock in perfect factory fresh condition, from there another 20 odd hp could be easly eaten up by any one or more of the things i listed and others i didn't, dynos can be way off too compared to other units of the same brand/model depending on how it's set up and correction factor. the good thing is now that you have a base line you can go back to that same dyno and with the same correction factor will be able to track improvements
On 10-13-2005, shogun posted the following (with irrelevant parts cut out, but none added):Originally Posted by Qube
Originally Posted by shogun
Shhhhh! Don't discredit the shogun reset! It works a silent miracle... like the button on Lost (http://www.lostpedia.com/wiki/Main_Page)
Thats like saying the white man invented smallpox when we came to american, when we were just carriers.
