Originally Posted by winfred
Thanks Winfred - here's my issue - with my aftermarket ECU I am tapping the switch +12v on the main relay for power to the ECU. When I shut the car off it keeps running until fuel pressure runs out (fuel pump turns off with key but it seems the main relay is holding closed for a while). I am thinking of making my own "main" relay. What do you think I should do?
It is not a manual you can buy ... it is from my archive of collected data over the past 40 years or so.Originally Posted by JMI
The early half has been converted to pdf and the rest is electronic anyway, now in the form of Word and Excel files.
It is very possible that a main relay could be like any of the contact layouts shown; I can think of reasons for all scenarios.Originally Posted by Jon K
However, to achieve what you say, you could use any of the '5-blade' types in the picture or the '4-blade' type with 'NO' contacts.
Just wire the ignition +12volt to '86', vehicle ground to '85', battery +12volt to '30', then '87' to the positive contact on the device you wish to switch, with the other side to vehicle ground.
If your relays don't have all the markings, use a multimeter to check out which contacts are connected or not, bearing in mind that the coil resistance is likely to be in the range of 50 to 1000 ohms.
'90 535iSE Auto (AE+EAT) 123k miles
'86 F288 69k miles
'06('89)- PGE 2.0DOHC Turbo
'03 A160LE 19k miles
1914 Stellite E2A (no odometer!)
(+ others I daren't mention here)
www.pyghtle.com
