Results 1 to 4 of 4
Thread: Any tips for troubleshooting/diagnostic heating system?
    Fogtown
    Default Any tips for troubleshooting/diagnostic heating system?
    My passenger heat does not work. I already replaced the heater valve (broke it during a cleaning procedure). I am pretty sure my aux water pump is not fuctioning (pluged it in, put the car in run position, didn't spin) but I doubt that is causing the problem as the driver heat is working. What should I check next?
    Fogtown
    Anyone?
    baton rouge, loserana
    it's easy to test the motor, connect a hot and a ground and it will run, generally if the motor is not working if you get any heat you are lucky, the cooling system just doesn't supply enough pressure to circulate the coolent through the extensive amount of plumbing, it will follow the path of least resistance
    Fogtown
    Is the aux motor meant to be always on when the car is in run position or only when the car warms up? As I said, the way I tested it: pluged the motor into the plug, put the car in run position, nothing spun. I get a good amount of heat by using the driver heat and the face vents.
  1. Replies: 0
    Last Post: 02-28-2009, 11:52 PM
  2. Replies: 0
    Last Post: 02-28-2009, 08:05 PM
  3. Found some helpful diagnostic tips searching around.
    By Felixdacat in forum 5 Series BMW
    Last Post: 12-18-2006, 07:26 PM
  4. Major loss of power. Troubleshooting tips please
    By RIPDOTCOM in forum 5 Series BMW
    Last Post: 11-17-2005, 03:51 PM
  5. Heating system question - Valeo non A/C
    Last Post: 11-10-2004, 06:37 PM
