only some cars have the fan, theres a place for it in all of them it's just not installed
Where? Bentley says there is an E-Box fan, 2", but I don't see one...
I have one in the E32 750, sits behind the glovebox compartment. If you follow the plastic chute from the IHKA to the e-box, you'll find it. Sits behind the carpet in a black plastic box. Can be disassembled from the cabin when it starts singing/chirping like a bird.
Costs around 50 $ and looks like a fan for a PC.
Which cars?
Not sure mine has one. If so where is it located?
My 535, build Nov '88 has the fan.
erased due to slander
Is the fan an inlet or exhaust - does it suck into the ebox or exhaust out of the ebox?
I think it blows cabin air into the ebox.Originally Posted by Jon K
Jeff's 90? 535 doesn't have the fan.
That is clear, it blows cold air from the aircon into the box. Has 2 speeds and in the e-box is a temperature feeler. Always blows, 2nd stage at 44 degree celsius.Originally Posted by Jon K
http://www.realoem.com/bmw/showparts...51&hg=12&fg=35
Part 12901720343 (BLOWER UNIT) was found on the following vehicles:
E31: Details on E31
E31 840Ci COUPE
E31 840i COUPE
E31 850Ci COUPE
E31 850CSi COUPE
E32: Details on E32
E32 735i SEDAN
E32 735iL SEDAN
E32 750iL SEDAN
E32 740i SEDAN
E32 740iL SEDAN
E34: Details on E34
E34 525i SEDAN
E34 535i SEDAN
E34 525i TOURING
E34 530i TOURING
E34 530i SEDAN
E34 540i SEDAN
E34 M5 3.6 SEDAN
Wow that is interesting Shogun - they are airconditioning the ECU box? That's going to introduce moisture without a doubt. I saw that there are "blanks" in the rubber sealing around my ECU box but I didn't know what would go there. Looks like I may throw a little 60mm fan in there for some added cooling.
air thats cooling the box. Unless you have a humidity controlled prius.
