Results 1 to 10 of 17
Thread: BMW TDC marks totally blow
    PA
    Default BMW TDC marks totally blow
    That image was taken with a Canon G5 in MACRO mode with a mirror... thats the only way I could even see into the space where the marks are at. I set the motor at tdc and went down to the oil pan and did this:
    I guess BMW didn't really intend the timing to be "checked".
    The marks are only there for assembly, the DME checks the timing and you can check the DME.
    baton rouge, loserana
    yep
    Quote Originally Posted by joshua43214
    Maryland, Virginia, D.C.
    East Brunswick, New Jersey
    Another way to check it is at No. 1 piston TDC, you can insert a 1/4" diameter drift under the starter to lock the flywheel.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    USA
    yeah.... but he removed the stock DME!
    Hockinson, Washington
    Quote Originally Posted by BillionPa
    So he shouldnt be complaining about the TDC marks.
    PA
    Need TDC marks to do anything with an ECU - they should make them readable what if an M30 or M20 with distributer has a misfire/distributor lock problem?
    No, what blows is seeing the unused crank position sensor boss & thinking it was lost after doing belts & a water pump. The boss is still there on the S52 as well as a friend's (97) 328 motor, m25 maybe?
    erased due to slander
    nah that's what makes it easy to drop that motor in place of a m50
    Quote Originally Posted by Martin in Bellevue
  1. Removing Swirl Marks
    By gjmane36 in forum 5 Series BMW
    Last Post: 07-13-2007, 11:46 PM
  2. White Marks on Black Paint
    By vaaccess in forum 5 Series BMW
    Last Post: 01-23-2006, 11:19 PM
  3. Woo Hoo, I ordered Marks chip yesterday!
    By Keith in forum 5 Series BMW
    Last Post: 03-31-2004, 06:57 PM
