Results 1 to 4 of 4
Thread: Power Steering
    Default Power Steering
    Do the power steering and auto tranny use the same fluid, I mean are they linked together or are they independent systems? BTW the I have the M50 motor with the GM transmission.
    Jul 2004
    Default Read The Label
    Quote Originally Posted by 94_e34_525i
    Find the power steering fluid reservior and before doing anything, READ THE LABEL on the cap. THAT will tell you exactly what fluid to put in. For example, if the cap says "ATF Oil Only," then yes, the fluid should be standard Dextron III.
    IF, however, it states "Pentosin 11s" or "Pentosin 7.1," then USE ONLY THAT FLUID!
    Don't mix and match; Don't try to substitute; READ THE LABEL and use only that fluid!
    Thanks for the info but, let me clarify my question is the fluid in the resevior the same stuff thats in my transmission, it says ATF so I know I put ATF but what I meant do the two mix with each other. Thanks.
    They do not mix.
  1. Power steering cut out
    By stx133 in forum 5 Series BMW
    Last Post: 08-19-2009, 06:41 AM
  2. Power Steering
    By PLATINUM in forum 3 Series BMW
    Last Post: 09-02-2008, 09:28 AM
  3. power steering
    By allerston in forum 5 Series BMW
    Last Post: 07-08-2008, 01:15 PM
  4. Power Steering Help!
    By realness in forum 5 Series BMW
    Last Post: 04-01-2008, 02:52 PM
  5. Replies: 10
    Last Post: 02-01-2005, 01:25 PM
