are you replacing it with an m30 or an s38
I'm going to have my engine replaced in the coming week and I wanted to ask you guys what parts I should replace while the engine is out? engine and tranny mounts? Anything you guys suggest?
m20 if I remember correctly.Originally Posted by angrypancake
M20
You really want to do all the major maintenance items, there'd be a list on bmwe34.net- but for starters-
Stuff that is nice to do (unless what you have is shot)
- All heater hoses- unless you know how to tell if they are relatively new- and are sure.
- Water pump and thermostat
- Oil pump and chain, sprockets
- Timing chain, tensioner and sprockets or belt
- Pan gasket
- Vacuum hoses
- BMW coolant - with a decent block, heater core and radiator flush
- belts
- Drain and replace Transmission fluid, filter AND power steering fluid (Synthetic is a nice touch)
- O2 sensor
- Main seals (front and rear)- plus transmission output seal
I think that's it... Nick
- fan clutch
- filters
- plugs
- ignition wires
- rotor cap+button
- Differential oil
- Engine and transmission mounts
- And of course the dogbones are always worth checking
