Results 1 to 5 of 5
Thread: e34 520i 1988 brake servo/check valve...
    Default e34 520i 1988 brake servo/check valve...
    Hi,
    Can i convert stock check valve (with multiple vacuum hoses) to simple 2-port check valve- one to servo and another to manifold? of course, i'll seal the rests.
    Or there are reasons why it's being designed like that?
    My check valve leaks at # 17 inlet, which i am interested to know where it goes to. If i cover it with my finger, the engine idling goes up and down... I thought, i could make it simpler with 2-port check valve...
    Appreciate for any help.
    thanks in advance,
    rahman
    Rahman in Kuala Lumpur,
    1988 520i M20B20
    1988 730i M30B30
    1982 323/6 M20B23
    1980 316
    1984 GPZ550
    Part 17 is a vacuum cap. Just put new cap on, you can get them from any autoparts store, or find something rubber to stick over it. The check valve is technicaly a metered vacuum leak to the servo, if you use something in its place that meteres a different amount of air, you can have idle diving or idle quality issues especialy after hard braking. Picture coming to a hard stop behind someone who suddenly decided they just now needed McDonalds and your car stalls on brakeing, or the engine surges(very bad on auto cars).
    A piece of vacuum hose with a BB in it works even if its not elegant.
    Quote Originally Posted by joshua43214
    Josh,
    Thanks for the advise.
    I just use a one-way valve found from my e21 as replacement to the check valve assembly, and it works so far. BTW what is a "BB"?
    thanks...
    1988 520i M20B20
    1988 730i M30B30
    1982 323/6 M20B23
    1980 316
    1984 GPZ550
    Quote Originally Posted by nsbone_1988_520i
    Josh,
    thanks...
    A BB is a .17(?) caliber pellet used in childrens pellet guns
    Oooo... ok... thanks, i used something similar (spark plug/large nut)...
    1988 520i M20B20
    1988 730i M30B30
    1982 323/6 M20B23
    1980 316
    1984 GPZ550
  1. 520i E34 - Check Engine light?
    By andylarox in forum 5 Series BMW
    Last Post: 09-20-2008, 05:30 PM
  2. Brake Booster (Servo) Leak - E34 540
    By black_bird_blue in forum 5 Series BMW
    Last Post: 04-16-2007, 11:32 AM
  3. Where is the check valve in the brake booster?
    Last Post: 11-21-2006, 01:42 PM
  4. 520i E34 brake pipe diameter
    By Spandit in forum 5 Series BMW
    Last Post: 03-22-2005, 07:23 PM
  5. rear diff option for 1988 520i e34
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 12-13-2004, 01:27 PM
