In the E32 that is installed on all cars from built year 09/1991
actually it is just a new GM
-Repeat and time interlock for headwashers, time interlock 3 min.
-headlight washing pump at fifth windshield washing after time interlock
-intensiv washing pump operating at reduced time from 3 to 2 seconds
-minimum interval for wipers reduced to 2 from 3 seconds (programmmable)
-increased wiper contact pressure during windshield washing now also provided
-previously the GM would react opposing signals (e.g. an unlock signal while trying to lock, as with a defective microswitch) by carrying out the first command (e.g. locking, followed immediately by unlocking). Repeating the first command then results in carrying out the command, e.g. try to lock again, and locking is now carried out. This function (Asynchronious Position)is omitted in the NEW GM.
-After unlocking is performed due to crash sensor activiation, the locking command is now reactivated by double-locking with the key from either side (driver or passenger door).
-The one-touch operation of windows has been expanded to all 4 windows in OPENING direction. Drivers side has one touch in both directions
Sunroof is not already in the tilt position.
-switch off delay of the interior lights after entering the vehicle and closing the driver's door reduced from 20 to 15 seconds.
new GM from 09/91 is 6135 8 356 095
further GM's
1) 61 35 8 356 552
2) 61 35 8 368 158
3) 61 35 8 350 345
4) 61 35 8 360 105
amd more if you check the realoem.
PS: only the drivers side has up and down one touch function, the others for safety reasons only down
