By cool air I mean un-heated air (same as ambient external temperature). I can’t feel any difference in degree of temperature when I adjust the dials.Originally Posted by Javier
I’ll check/follow-up on your suggestions/advice when I have some time and I’ll keep you posted …thanks.
The first image below shows the region you’re referring to (red circle on the lower right). The power resistor appears to have leaked/oozed some material that has hardened (‘browned’ where coincident with subjected heat). There are also other areas (integrated circuits) that show similar features (circles with red ellipses). Is this normal? (i.e., thermal transfer paste/compound/adhesive) I’ve never seen anything like this on any motherboards, NICs, video cards, sound cards ..etc that I’ve seen.Originally Posted by pingu
Thanks for the soldering write-up/advice …..
