Cripes, 2MM is less than 0.080" - well thinner than the backing plate. I've got years left on mine.Originally Posted by Bill R.
Anthony
03/64 production
will be familiar with the process, its frequently used as a thin protective plating to help increase an objects ability to dissipate heat. The electronics industry uses it frequently.
I personally am too cheap to do anything like this. This was for those people going to the nth degree. If i put rebuilt calipers on my car , dissipation would be my prime concern, not appearance. So if it was aluminum I would glass bead the outside surface with a fairly coarse grit to increase the surface area and improve heat dissipation and leave it a plain aluminum finish. If it were iron or steel calipers i would either use a very thin coat of ultra flat black paint or just a coating of stove black, either of which would have the least effect on the surface as far as retaining heat. I would never paint the hats on the rotors since the plain iron would transfer heat better. To some degree the wheels themselves might act as heat sinks for the rotors in addition to the vented castings on the rotors themselves. So by not putting a coating inbetween the rotor hat and the wheel and hub you may help heat dissipation to some small degree. This is probably splitting hairs but why bother going to these big rotors and large calipers and then painting them all up to retain heat?
Originally Posted by BigKriss
