inspection time, hopefully its only the guibo or something like that. anytime you get that its from slop in the driveline, could even possibly be the cv joints.
Yesterday I was driving along, and all of a sudden my gearbox starts rattling/vibrating quite badly. It's not a violent shake, but it sounds and feels absolutely horrible. It has a sound similar to if you let off the clutch a little early and you grind the gears a little, but not as violent, but it's a constant noise. It's really only noticeable over 30mph.... below that it's not all that noticeable.
Change your fluid to Redline if no major damage visibly seen
guibo ???
Derek A.
90 535i 5 Speed - Style 5 17"
guibo = flex disk on driveshaft.
Hopefully guibo or centre bearing.... clutch even... ? Good luck! To visually check you have to pull the exhaust and the drive shaft. Any noise transferring from the middle of the car? That would mean less trouble...Originally Posted by Wyn
