Thread: Can 1998 M Roadster rims fit on the E34?...more..
    Sid The Kid Guest
    Default Can 1998 M Roadster rims fit on the E34?...more..
    ...if not can i modify it to make it fit?
    Holland
    They will not fit. You can use spacers to fit them.
    Greetings from Holland
    baton rouge, loserana
    use spacers only if you like the shimmey
    NJ
    Default The rears should fit
    From memory, the M-coupe/roadster used 17x9 rear wheels with a 26mm offset. The fronts would probably require big spacers (~20mm). The only good news about the large spacers is that they shouldn't shimmy because they have a "surrogate hub" built in.
    Drew Zacharda
    6-speed Touring
    Quote Originally Posted by Sid The Kid
    Unregistered Guest
    so the front should fit no problem, its only the rears that need spacers? how much would this all cost?
    thanx guys
    Quote Originally Posted by DrewZ
    Drew Zacharda
    6-speed Touring
    NJ
    Quote Originally Posted by Unregistered
    thanx guys
    You got it backward. The fronts will probably require spacers; the rears should be fine. Find out what the offsets are, then you'll know whether they'll fit.
    Drew Z
    Formerly 540iT/6, now . . . 3, 5, 7
  1. :: e34 for a 225hp TT Roadster
    By Qube in forum 5 Series BMW
    Last Post: 10-20-2007, 06:39 PM
  2. OT: 2000 M-Roadster...How much??
    By athflying79 in forum 5 Series BMW
    Last Post: 04-19-2006, 06:24 PM
  3. Z8 Roadster or Ferrari 360 Spyder?
    By Evan in forum 5 Series BMW
    Last Post: 10-06-2004, 12:35 PM
  4. z3 roadster/ key question
    By JeremyT in forum 3 Series BMW
    Last Post: 08-20-2004, 02:49 PM
