Results 1 to 3 of 3
Thread: OBC Display
    Jun 2006
    green bay wi
    Default OBC Display
    my healights all work on my 90525i but when i turn on the headlight it chimes and shoews low beam but all is good is there a sensor for the head lights?
    thanks
    Do you have a European specification car with auto dip function for the low beams? In that case there are small motors behind the headlights (accessible from engine room). These motors draw too much power and cause such alarms. Remove the plug from the dip motors and see if there is still an alarm.
    I understand that all lights work fine, but that you get an alarm.
    If it is the other way round, that you have failures of lights, then resolder the socalled mustard relay and the LKM, all mentioned on my website below under e32fixes.com
    Pls use on top of this page at left side the User C/P and complete your profile with relevant car data such as built date, engine type etc., as shown here on the left under my name. Helps a lot to help you.
    Honolulu
    Default No sensor
    The lights are run by the LKM, the warnings are run the the CCM.
    Your problem is probably dirty contacs or cheap blubs.
    Check the wiring and plugs for your lights
  1. CEL / dashboard display
    By timandbim in forum 5 Series BMW
    Last Post: 08-27-2007, 12:23 PM
  2. Radio display goes in and out
    Last Post: 04-03-2007, 06:41 PM
  3. Mileage display
    By richie535 in forum 5 Series BMW
    Last Post: 11-06-2006, 12:31 PM
  4. BC Remote Display
    By BlackOnBlack in forum 5 Series BMW
    Last Post: 08-08-2006, 12:48 PM
  5. can anyone tell me how to resize the etk display.....
    Last Post: 04-17-2005, 09:34 PM
