Results 1 to 9 of 9
Thread: Replace DME Relay and Fuel Pump Relay - not expensive.
    Seattle, Wa
    Default Replace DME Relay and Fuel Pump Relay - not expensive.
    Have had 3 incidents of the "Trans Program" warning at about about 6 week intervals. I'm getting concerned and looking for remedies. Have change the trans filter and added new oil.
    Can someone explain why doing this:
    will help?
    I don't see the connection.
    TIA
    Jim
    Seattle, Wa
    Anybody?
    USA
    i think the DME relay controls a ground to the trans comp. (or maybe forward voltage)
    a bad ground to the trans computer would cause the error.
    if you havent replaced the fuel pump and ecu relay you should do it anyway.
    Seattle, Wa
    Its about $20 per relay so I'll do it. Just wanted to know why.
    Thanks
    Seattle, Wa
    Had another "Trans Program" warning so ordered the relays. Like a sheep following the flock I replaced the 2 relays today . Hope that is the cure.
    Still, I'd be interested to know definitely how/why these relays will help.
    TIA
    Jim
    Default It won't be the cure.
    Quote Originally Posted by JMI
    TIA
    Jim
    Seattle, Wa
    Bill,
    You have had experience with the "Trans Program" and the replacement of the relays?
    Seattle, Wa
    I made several threads/posts about my "Trans Program" with limp mode problem. Tried several "fixes" but bottom line is I changed out the Pulse Generator ($40 from stealer) in the transmission (remove pan and it is right there, very easiy job) and no more "Trans Program"!!!
    USA
    i was able to throw a trans program instantly today, by unplugging the shifter lock solenoid.
    another place to look at before having a trans rebuild.
  1. Fuel pump relay - WHERE???
    By wool in forum 5 Series BMW
    Last Post: 10-01-2009, 12:00 PM
  2. Fuel Pump or relay???
    Last Post: 07-25-2007, 11:51 PM
  3. M50 coils, main relay or fuel pump relay?
    Last Post: 05-31-2006, 07:48 PM
  4. Fuel pump relay
    By iainand in forum 5 Series BMW
    Last Post: 04-18-2006, 11:24 AM
  5. Which Relay is Fuel Pump Relay (PIC)
    By Jim525it in forum 5 Series BMW
    Last Post: 03-19-2006, 08:43 AM
