Results 1 to 5 of 5
Thread: help, 540i/a still running rough
    SCHUYLKILL COUNTY, PA.
    Default help, 540i/a still running rough
    my 540i/a is still running rough around 1000-1300 r.p.m.s. it is driving me , it seams to run a little lean, when the temp outside hit 70 the car ran smoother, in the past 3 months replaced plugs, boots, o2 sensors, icv plate, did injector cleaning service, compression tests o.k., but still runs rough. dealer claims it's fine, but i noticed a lack in power, even at the upper 5000rpm power band that i really enjoyed. i am running out of idea's, we also tried to find vaccuum leaks. found no leaks. i am looking for more suggestions. could it be a temp sensor?
    thanks
    a very frustrated tim s.
    1995 540i/a
    1987 325e
    new540iwoner Guest
    Default If you're getting the 1221 error code,...
    you may want to replace the Oxygen Sensor Heater Relay. I replaced mine
    and the car runs fine.
    baton rouge, loserana
    i've had v8s come in throwing intermitant o2 sensor codes and running bad at certain times, plugged cat/cats is one cause and another being intake manifold gaskets, the intake gaskets can be a bitch to find because they don't always leak, some times they seal up when the motor warms up, we just did battle with 3 e38's in a row that had intake leaks and or plugged cats in the last month. they use gaskets of the same materal as a m50 but i guess the amount of oil that the v8 ingests through that crappy pcv system kills them, i don't even bother changing the gaskets on m50/52 when i need to pull the intake, they seal up great, but they get rock hard and crack on the v8, if you change them don't forget to do the throttle body gasket too
    Default how much harder is it to replace the intake.........
    compared to the valve cover gaskets.
    thanks
    tim s.
    a little, you need to dissconnect and lay the wiring harness off to the side before you can pull the intake
  1. running rough
    By edward in forum 5 Series BMW
    Last Post: 05-16-2009, 10:30 PM
  2. rough running
    By jippijak in forum 5 Series BMW
    Last Post: 02-26-2006, 04:46 PM
  3. 540i/a running rough continue's
    By tim s in forum Engine & Drivetrain
    Last Post: 02-27-2004, 09:22 AM
  4. 540i/a running rough!!! please help!!!
    Last Post: 02-21-2004, 03:37 PM
  5. Please Help!!! 540i/a running rough
    Last Post: 02-19-2004, 04:12 PM
