Results 1 to 10 of 20
Thread: Need Help Finding Computer For 1991 M50 Motor!!!
    Jun 2006
    Default Need Help Finding Computer For 1991 M50 Motor!!!
    I am looking for a computer for a M50 motor. I switched out my bad M52 out of my 94 and replaced with a 91 M50. So now I need a computer for the M50 motor. When I started the car with the M52 computer some wires started smoking. Does anyone know where I can buy a main computer for a 1991 M50 motor?
    Aug 2004
    RTP North Carolina
    Default # needed
    What's the bosch number on the side of the unit?
    example below...
    PA
    Gonna be a 403 I think
    Jul 2005
    Cologne, Germany
    yes, should be 403 or 405. and btw., your '94 engine is a M50TU, not M52.
    hope you also have switched the engine wiring loom, air mass sensor and so on?
    greets from Germany,
    Kai
    A BMW is a black car with most rights in road traffic.
    Toronto, CANADA
    You can use a 405, 403 or 402. The 402 was the last version and then the M50tu used the 413. Why did you even try to run that motor with a 413 ECU? It's completely different, it has VANOS and knock sensors which the earlier M50 does not have.
    As Kai mentioned, you need to change the harness also. It would have been much simpler to drop in another m50tu or even an m52.
    MarkD
    baton rouge, loserana
    a vanos brain and harness running a non vanos motor should not automaticly smoke, properly hooked up theres a chance it may even run ok (with a obvious vanos solenoid code, unless he swapped in the cams and mounted the servo) i am guessing something wasn't hooked up right under the intake, had a car come a couple years ago that a boat mechanic?! had installed a motor in for the guy that he bought from us that had popped 4 computers one after the other (douchbag ya think he would of learned) turns out he had some sensors crossed up and the computer was back feeding itself and frying various things, computers among them
    Jun 2006
    Thats the problem. I do not have the old ECU from the M50 motor. I just have the M52 ECU. Do you know how I can find out what number I need for the M50.
    Jun 2006
    what do u mean 403 or 405? Do you mean I have to replace the entire wiring harness?
    Jun 2006
    What do you mean 403? Is this number on the ECU itself?
    Jun 2006
    Quote Originally Posted by MarkD
    MarkD
    I did not know it would be this difficult. What do you mean by the numbers? Does this mean all the wires have to be replaced? Even the ones that go to the lights and so on?
  1. Replies: 3
    Last Post: 08-13-2008, 12:16 AM
  2. Engine computer M50 1991
    By volney in forum 5 Series BMW
    Last Post: 10-20-2006, 05:06 PM
  3. Replies: 30
    Last Post: 04-02-2005, 11:56 PM
