Socket, wiring, or bulb control unit, in that order.Originally Posted by Eric K
The right rear light on my 1987 535is is not working. The bulb is fine and the fuses are ok also. Any other ideas of what i should look for.
1997 535i V8
Clean all contact points using a fine file or screwdriver.
Greg Mendoza
so, being fuse 9 OK, look for the "Rear Lights Check Relay", located in the trunk per the picture. You need to have low resistance conduction between pins corresponding to the Grey/Black and Grey/White wires. If not, you may open the relay box and check soldering point at corresponding circuit path. It is a relay coil.
Javier
