Auxiliary Fan is not working ('95 525 iT).
My Auxiliary Fan is not working ('95 525 iT).
I had the evaporator replaced last year to the tune of $1800.00 including a new auxiliary fan. for $400.00. I wanted to put in a used fan but the shop said they couldn't do the job without a new fan. I didn't notice whether it worked or not because I was out of state on a trip but now I'm sure that it doesn't.
Recently I replaced both relays since the old ones were charred but still nothing. What I am not sure of is when this fan is meant to come on. If the A/C is on and the engine is warm, then the fan should be on too, yes?
I have a Bentley's manual but am unclear of the different components that make up the aux fan circuit. The first thing to do, I suppose is to see if can get the fan to run at all with a direct current to the fan and I understand there is a resistor on the front top left of the radiator and also a switch on the top right of the radiator. Two relays and two fuses #29 and #25.
The reason this bothers me is that not only did I pay more money to have this A/C problem fixed than I have ever spent on a car, period but the motor knocks a bit under load with the A/C on.
Thanks for any thoughts,
Bowman Kelley
1995 525 iT 112000m
