Results 1 to 10 of 10
Thread: Noise while turning?
    CT
    Default Noise while turning?
    Makes a noise similiar to a door opening in a horror movie (or walking on an old floor). The noise is louder when turning the steering wheel to the left (makes the noise with small turns of the wheel). Had all control arms, pittman, and tie rods replaced.
    Do I need to replace the steering box?
    May 2006
    Antwerp, Belgium
    Quote Originally Posted by Jzza4
    Isn't there supposed to be lubrication involved here? Anything that creeaks or squeeks needs greasing or oiling as far as I know. I'm curious now.
    Power steering fluid full? Could be upper strut bearings or the spring pad. Its best to have an asistant turn the wheel while you listen and touch parts. Steering noises can almost always be felt with your fingers.
    Did you buy quality control arms? I have seen new ball joints make noise with cheap parts before, pretty rare, but it does happen.
    Mar 2004
    Sway bar links made a similar noise in my E28.
    Paul Shovestul
    CT
    Parts replaced with oem except for the 750 bushing/control arms from bma.com (if that matters).
    Do they need to be relubed?
    Boston & Attleboro MA
    I 2nd Bellicose's opinion, my sways which I've been meaning to replace give me a similar noise.
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    no they dont need lube, did it make the noise before it was all replaced?
    CT
    It made the noise prior to replacing the steering components. It seems to be getting louder over time. It also made the noise prior to getting 18" rims.
    The pittman arm was not replaced (the idler arm was). Could that be the problem?
    One more question. The rear vibrates a lot, especially during acceleration. Sway bar links and bushings replaced. Should I replace the subframe mounts (bushings)? I also read a post a few days ago in regards to the delrin inserts which said not to use them, is this true?
    Thanks for everyone's assistance. Fix these problems and it truely is a new '95 525i (cause everything else has been replaced)!
    could be anything, you really should have the whole car inspected...sounds to me you have several issues and they all need to be fixed, not guessing and replacing parts.
    My guess is strut mounts.
  1. Noise right after turning car off...
    By HIe34 in forum 5 Series BMW
    Last Post: 12-29-2006, 05:26 PM
  2. Strange noise when turning the steering wheel
    By The Melmaan in forum 5 Series BMW
    Last Post: 12-08-2006, 07:34 AM
  3. Weird noise when turning
    By leetsauce4000 in forum 5 Series BMW
    Last Post: 12-02-2005, 05:55 PM
  4. Replies: 0
    Last Post: 09-15-2005, 10:25 AM
  5. A/C turning on and off at will?
    By madderlake in forum 3 Series BMW
    Last Post: 07-11-2005, 04:20 PM
