Results 1 to 10 of 13
Thread: A/C Vents Won't Stay Put!
    Fort Worth, Tx
    Default A/C Vents Won't Stay Put!
    Hey all,
    The A/C vents in my car at the top of the middle consonsole (above the radio and trip computer) won't stay put in the position I put them in. Whenever I try to move them either up or down so that the A/C blows on me, the vents just move all the way down all by their selves. Is there a way I could fix this? Does anyone else have this problem?
    Thanks
    Check if the motor brackets are broken. That is quite often the case and then it does not work.
    I once posted a fix for that with a bracket with a lot of pics. Should be in archives.
    Also go to my website below, search for Johan & Sean page and check for center vents. If you are unlucky the flappers are broken.
    Do you mean the knob rolls back down on its own? I have taken vents apart on other cars and added a paper shim on the roller to add some extra friction. Never tried it on a BMW, but my car does the same thing, I just havn't gotten arround to trying it yet.
    Orlando, FL
    Shogun,
    Good links, but I think he's talking about the actual vents themselves. (Air direction left/right; up/down from the center vents). Mine do the same thing. When they're hot and the plastic is expanded, they stay in place, but barely. Once the A/C cools them down they get loose and move around on their own shooting the incoming air at random.
    I saw a post somewhere where Gayle mentioned using one of the lines of loctite on them at the pivot points. Added enough friction so that they'll stay in place. I'll see if I can't dig that up. It's also on my "to do" list.
    John
    Orlando, FL
    Here it is... http://www.nmia.com/~dgnrg/page_37.htm She's using Loctite #242. Pics too.
    John
    Lexington, Kentucky
    I did this. worked great. just enough resistance.
    pull the vent out and look at the side and you should see a little C shaped piece of metal, you can pull that out and put a little bit of a bend in it to make it poke out and make more friction, or you can put a piece or two of fishing line behind it to make it stick out more
    Albuquerque, NM
    Quote Originally Posted by Gearhead
    John
    Correction, that's "gale" not "Gayle" and it's not "She". Besides, when have you ever seen a post by Gayle with any technical expertise?
    gale
    *hahaha*
    Quote Originally Posted by gale
  1. why won't my sun visor stay up all the way?
    By timandbim in forum 5 Series BMW
    Last Post: 01-12-2008, 03:06 AM
  2. headlights stay on after car is turned off
    By bryan1970 in forum 5 Series BMW
    Last Post: 01-12-2007, 08:44 PM
  3. heat through defrost vents but not through cabin vents
    By notesguy in forum 5 Series BMW
    Last Post: 01-21-2006, 03:19 AM
  4. '94 530iT Won't Stay Running
    By mxstav in forum 5 Series BMW
    Last Post: 09-02-2004, 10:38 AM
